disable bgp peer-group capability address-family vpnv4
disable bgp peer-group peer-group-name capability address-family vpnv4 type [community | ext-community] {[send | receive | both]}
Description
This command disables peer-group capability for a peer group on a Layer 3 VPN.
Syntax Description
remoteaddr Specifies the IPv4 address of a BGP neighbor.
vpnv4 Specifies the VPNv4 address family for Layer 3 VPN support.
community Disables peer-group capability for communities.
ext-community Disables peer-group capability for extended communities.
send Disables peer-group capability filter list send capability.
receive Disables peer-group capability filter list receive capability.
both Disables peer-group capability filter list send and receive capability.
Default
Disabled.
If the direction is not specified, the both option applies.
Usage Guidelines
Enter this command multiple times to configure the address family, type, and direction attributes.
By specifying the address-family, type and direction in multiple commands, you can better control the actual ORF capabilities sent to a peer. In the case where a particular address-family is explicitly disabled for a peering, the ORF capability configuration for that address-family is ignored and not sent.
ORF capabilities can only be enabled for IPv4 neighbors, and only for IPv4 address families. If configured for IPv6 neighbors or address-families the command is rejected with the following error message:
Outbound-route-filtering not supported for IPv6 neighbors
or
Outbound-route-filtering not supported for address family <addr_family>
The following command disables the peer-group capability feature for a Layer 3 VPN peer group:
disable bgp peer-group vpn capability address-family vpnv4
This command was first available in ExtremeXOS 15.1.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature,see the Switch Engine v33.1.1 Licensing Guide document.
